TwinTurbo.NET: Nissan 300ZX forum - Also, a leak at the tb shaft should be fixed if possible but
Evan_Wright (Ca)
on October 14, 2012 at 10:02 AM
Find a way to verify that gauge is working first.
posted by Evan_Wright (Ca)
on October 14, 2012 at 10:00 AM
there's no way it's leaking enough to prevent you from building pressure during a boost leak test.
Would leaking TB seals cause failing boost leak test?
smartone
21:48:16 10/13/12
Re: Would leaking TB seals cause failing boost leak test?
ZBOOSTT
00:48:06 10/14/12
Re: Re: Would leaking TB seals cause failing boost leak test?
smartone
01:14:25 10/14/12
I've never understood why people say only 5 psi....
Supermario680 (WI)
06:16:49 10/14/12
I am thinking the gauge is broken but not 100% sure yet.. (n/m)
smartone
09:53:14 10/14/12
Here:
Summeronthechain (MN)
10:12:00 10/14/12
Evan_Wright (Ca)
10:00:08 10/14/12
Also, a leak at the tb shaft should be fixed if possible but -
Evan_Wright (Ca)
10:02:46 10/14/12
